Last year i was given some spare 20" wheels from Maddox. Thank you very much.
And have since then pondered over how to use them.
I was so inspired by Stormbirds phyton, so I decided to build one.
It will have 20" wheel all around. I bought a "front" wheel with 8 gears and will use 2 of the wheels from Maddox in the rear.
The rear frame is build from 38.1 mm round tube with 1.5mm wall.
Im building the trike narrow, 25" rear tracking, and short about 900mm wheelbase.
So far I have welded wheel nuts to washers and then tacked the washers to the rear axel.
Next is to make the pivot.
