DIY Bike and Trike Plans
Results 1 to 20 of 24
Thread: Uncle Fred's Linear Pedalling Idea
Threaded View
  1. #1
    Join Date
    Jul 2009
    Adelaide, South Australia
    Posts
    1,294
    Default Uncle Fred's Linear Pedalling Idea
    Uncle Fred told me of a different way of powering a bike, using linear pedalling.
    I have started building some linear pedals for my F-RQ, and thought trhe AZKrew might want to see how I have attacked this idea.
    First:
    Liberate the cranks from the BB spindle mounts
    Second:
    Build a pair of freewheels with sprockets on opposite sides of the freewheels. This is to make sure you have a left side and a right side freewheel. These will be attached to the front gear cluster, to enable both cranks to individually drive the gears, or both cranks to drive at the same time.
    Close up of the thin freewheels I am using. I got them from the local flea market for $2 ea.
    Third:
    Purchase some decent door rollers, I am using sliding door rollers capable of supporting 34kgs per 4 wheels, and make a bracket to hold the rollers.
    Here you can see the rollers inside the track they run on.
    Fourth:
    Marry the liberated cranks to the new brackets, making sure the pedals are facing the correct way.! Mine are actually welded on wrong! I now have the pedals mounted to the back of the crank! DER!
    PeterT
    "Think inside the square, and all you will play with are boxes! Think outside the square, and the world will come running to you ... either to employ you, or to say that that can't be done, after you have already done that!" www.flickr.com/photos/patremlett/
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
