Since the Deltas have a split rear axle, we can use a separate motor to drive each rear wheel. then put a hub motor on the front wheel to have all wheel drive.
If someone electronically capable wanted, they could put one throttle on the handle bar to run all three motors. If they used an another throttle on the steering and a little electronic magic, they could have all 3 motors running at different speeds depending on how far and which way, the steering is turned.
It may be horribly hot now, but, when the snow starts flying , all wheel drive would be nice!
