DIY Bike and Trike Plans
Results 1 to 13 of 13
Thread: Riveted Aluminum Recumbent Tadpole Trike
Threaded View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Feb 2011
    Edmonton, Alberta, Canada
    Posts
    617
    Lightbulb Riveted Aluminum Recumbent Tadpole Trike
    I was wandering around YouTube today, looking at videos of various trikes, etc., and I came across a rather interesting trike build.
    It's a recumbent tadpole design, using aluminum rectangular section tubing and flat plate, riveted together, and gusseted at all the major angle joints. The builder mentions in his video a weight of 38 lbs.
    I found it interesting because the methods of joining the pieces with pop rivets reminded me of similar construction in plans for homebuilt aircraft, and because it appeared to be an entirely weld-free frame.
    You can see the video under the title "Raptor Recumbent Trike" at:
    http://www.youtube.com/watch?v=W5CIY9lPIsg
    A few close-up stills from the video are shown below:
    Click image for larger version.
Name:	Aluminum Rivited Tadpole 1 small.jpg
Name:	Aluminum Rivited Tadpole 3 small.jpg
Name:	Aluminum Rivited Tadpole 2 small.jpg
Name:	Aluminum Rivited Tadpole 4.jpg
    Food for thought for an alternate construction technique to welded steel.
    (P.S. As far as I could tell, the builder's choice of the name "Raptor" has nothing to do with the commercially built recumbents marketed under the same name).
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
