Ackerman angke
If you do not, then one wheel will be dragged across the ground in a turn, which results in...
- Extreme power loss due to friction
- Excessive tire wear
- Horrible handling
- Stress on bearings
If I had to choose between maintaining a proper Ackerman angle or running on the bare rims, the rims would be the best choice!
And never forget Ackerman's little brother, Centerpoint either...
The inside wheel follows a smaller circle when you turn than the outside wheel. Correct Ackerman angles ensure that the inside wheel is turned more than the outside one.
Va.
Ahhh good answers thanks . I’ll try ensure I don’t drag my tires😆👍
