The problem with any other profile than angle is attaching the panels. Angle gives a nice inside edge to glue them to and then run that same glue around the outer panel / angle joint to seal it. Round in particular provides a number of issues in that regard. Round would be great for stretching tent material around but not flat panels. My problem is in sourcing the size of angle I'd want. I can get 20x20x1.5 stamped but doubt it'd be strong enough but the next size up is 16x16x3 which adds 10kg or so. I did find one supplier of 15x15x2 in stainless only though and a whopping price - enough to be too much. 2mm angle appears largely the preserve of aluminium so maybe I need to try some aluminium soldering as it'd save 13-14 kg over the 16x16x3 steel. It's only supporting it's own weight so not a critical failure point.
The design above has a 90 degree bend in the steering. Perhaps I'm missing something and more detailed plans explain it. I see a few were built on the wooden ones you linked though. I see the issue with an overly wide track you mentioned in many of those too. The body on mine is barely wider than me with the tapered front.
