Another problem solved , nice
I put them on a flat face just inside the corner of the inner tube of the pair.Dan
Nice you are back ?
i thought the lockers went through the corners ?
Yes, it may well be. The placement of the rule on the tyres cause them to rotate so having only 1 hand available (camera in the other) it kept moving about.Dan
Nice work that man !
Although I think you need to visit Specsavers ?
Looks like 23.25" to me , my laddie ?
DanNow it is easier to do if you turn the frame over and have the BB shell threads the wrong way around. But I suppose one could locktite them in place to avoid any issues?
What do you think?
Paul,Dan
Ok a bit confusing as to were the seat will be in relation to the picture on the left ?
Can I suggest you drill some new holes in the seat & chains stays then strip the paint from the existing holes and weld them up ?
Python number one broke across one of those holes....
Not sure why you need to do this ?I need some "domestic management" agreement to the annexation of the dining room table so I can map it out. Or, I will cut the frame silhouette out in paper and pin it to the wall in the mini-barn.![]()
