Like it as well as the head lights.Not a Warrior but similar enough for this purpose.
Came from here. The seat pad had changed since I last bought one and I don't think the new one is as nice.
It's hollow, not bad, 10-12lbs, just have to figure out a mount.That certainly looks good but what does it weigh? Some gaming seats were 7-8kg or so when I briefly looked at them.
And removing the rocker part underneath.That certainly looks good but what does it weigh? Some gaming seats were 7-8kg or so when I briefly looked at them.
can you sent me a picture of your handle bars/controls, that's what I was thinking of for mine the bars under the seat are a little uncomfortable to be.I used a wooden seat that was shaped.
But my next seat will be this.
More support on the sides, do I don't slide off in corners. I have also the soft part for it, but I will get it from the same material that I have on my wooden seat.
This seat is also a lot lighter.
The wooden seat sits good, but it is narrow, so for touring, the other seat is better.
I have already several on this forum.can you sent me a picture of your handle bars/controls, that's what I was thinking of for mine the bars under the seat are a little uncomfortable to be.
Some use a single left and right for the front and no rear brakes, so you can use one if you want. But I prefer also one in the rear.Thank You so much, I never knew these existed.
Another question, is there a need for handle's on both sides or is one enough.
