Camper for my trike build.
I got today my wood and a round 25mm aluminum profile. The aluminium round 22 fits perfectly in it, so it is great for the legs.
Tonight I will measure the wood, mark it where to cut and then I can cut them shen I have time. I will gleu the long parts guest togheter.
Only need isolation foil straps to fix the coraplast and some filt for on the floor. But I start with the wooden frame, so that can wait.
I got my solar panels today for on the camper.
Now I need to gleu the wood, so it us thicker.
After that I can cut it.
I wanted to cut it first, but glueing it first is easier.
Yesterday tested the solar panels with the mppt charge booster and that works great. 1,3amp with one and 3,7amp with 2 solar panels.
I will probably order more, that I store under the camper. This way I can charge more and faster as I stay somewhere and I will not need an power outlet that much.
Almost glued all wood. I cut a few pieces and I will try to make the outer part of the frame ready today.
I hope that I can do the inner part this weekend and that I can put it all together next week.
But I need to borrow some tools before I can do that.
Hopefully, I will have the bottom part ready by the end of next week.
As I decided to keep Paul Elkins dimensions, I started to put his design in inches in 3d.
I found out, that as I take over his design in wood, it will not fit. So I made some miner tweaks.
I am constantly changing all dimensions to the metric system. So much easier and better.
It takes dome time and i check everything double, but it makes that I find the small mistakes in the design and can solve them, before I build it.
This Saturday the tempura is a bit lower, so I will probably also work a bit more on it.
More power to you Emiel. Making good progress.
I will soon post some images.
I did some more work today and tomorrow I hope to cut the front part.
As that is done, I can start to put the outer part of the bottom part togheter.
The inner part will follow soon, but i need to check how thick the wheel mounting plates will be and how width the mij Ying gor the wheels is. As I am right, it is 90mm, but I need to check that.
Wood cuts good, and with my angle grinder, I can sand it all very fast.
It goes faster than building with steel as you do it without machines.
Not put together yet, but I have now the outer part, complete. Probably will I need to cut one new top part. It is a few mm shorter than the others.
Today I will probably do some tests with epoxy, so I can put the top part togheter tomorrow.
Rest will follow soon. First I need the parts for the wheels to mount to.
Where I was ahead in my work, I now lost a bit of that.
Sunday and today where very hot. Today I hot my first vaccination and I went on my trike.
Riding went great and even with the high temperature it was no problem on my trike. So I decided to do an other short trip today instead of working on my camper.
I am still ahead of my planing and I have still a lot of time left.
So I will probably go further tomorrow, but I jyst do a few things. Probably cut a new piece for in the front and look for some parts that I can use to mount the wheels.
Next week, I will pick up the isolation and the bottom part, needs to be finished by then.
Have a nice aluminium pipe to connect it to my bike. Light and strong.
Need also mod the mount to the bike. There is a lot of play, so I will solve that with some 3D prints.
This week, the last parts for my solar panels will arrive. Then I can charge my bike batteries and as I get a 12v battery, also charge that.
