I have the plans for both the Timberwolf and the DeltaRunner. The frames are similar in that they have the same back end (Drawing 1 in the TW plans) and are made of 16g 1-1/2" square tubing but the DR has a solid 60" main beam and the TW is two piece to incorporate suspension. Both the TW and DR have 26" rear wheels on 5/8" axles but the DR also has a 26" front wheel compared to the TW's 20" front wheel. So this kind of makes the DR a hardtail version of the TW with over seat steering and a 26" front wheel. Given the similarity of the frames, I would expect you could start with a solid main boom on the TW and cut it later to incorporate a pivot.
Here a couple of pictures of the DR from the AZ plan page showing the solid main boom and a closeup of the rear frame.
If you still have concerns about flex/support with the 60" span on the DR, I would point out that each of the main beams on the Kyoto cruiser is 68" long so there is precedent in the AZ plans for going even longer.
Hope this helps.
