Delta two wheel drive (2WD)
Arundel, Maine
Hey Folks,
I have a Timberwolf delta in progress and am thinking about how I might make it 2 wheel drive. On the old AZ website forum there were one or two examples where people were able to make a two wheel drive with a pair of freewheels, but I don't recall the details and that thread disappeared with the old AZ forum. Is anyone here able to help, maybe with sharing your take on this through your own or someone else's project? Thanks!
-Ethan
Ethan
Many years riding a Hase Delta in the UK , always though I would one day tackle one of Brads.
Yes I would be tempted to make it 2wd , there is a condition the Hase suffered from rarely where when riding up a steep hill the lightly loaded from wheel would hop across the path away from the driven wheel.
In the UK this was relatively benign as the hopping took you away from any road traffic , that would not happen in some other countries..
So to achieve 2 wheel drive you need an additional drive shaft between the wheels and the pedals.[ called either jackshaft or layshaft ]
Take the existing rear wheel shafts and add 2 free wheels and don't add the cassette.
The new shaft runs in similar bearings to the wheels [ although you may get away with only 2 sets ? ]
On the shaft is a free wheel for each rear wheel and between them in line with the pedals is the cassette.
If you can get the angles and distances correct this can have the benefit of completely replacing the pulley under the seat for chain management .
The other way is probably harder to engineer but looks neater with less chains etc.
The 2 shafts in Brad's design terminate in the middle of the trike on a pair of freewheels , now imagine the free wheel as a pair of plates the outer plate is connected to the each rear wheel , the inner plate is connected to the other inner plate with a single gear wheel sandwiched between them and the free wheel mechanism allows drive between each pair of plates as per a normal bicycle.
So the chain drives the centre gear wheel and if conditions are right both rear wheels turn
On initial assessment this is not good as you only have 1 gear ?
However it then gives you the ability to have either a IG hub or a cluster driven from the pedals and then on to this single gear.
I can draw the first example and have a coloured drawing from the old thread of the centre of the second example.
I believe the old thread can be found on the Internet Archive = Wayback machine.
try this , it may help muddy the waters ? Free wheel diffs
Someone cleverer than me will be along shorty to explain this better.
If there is any of it you don't understand please ask , it was not my intention to confuse you .....
Columbus, GA
Ethan I made a quick drawing on the linked thread (post #79) that may help you
Arundel, Maine
I actually have a 2WD delta with suspension on each of the two rear wheels that was designed (mostly, as I understand it) by John Tetz and built by Rick Sadler since John's Parkinson's had advanced too far for him to build it himself at that point. [url=https://postimg.cc/94KF4fSm][/URL]
WFcycle
very sad to hear of John's illness , is he still riding ?
I know he was in his 70's when he helped me a while ago , he always did impressive inspirational work a real pioneer.
Ok can we have some larger pictures please ? hard to see how it is sprung from the drawing.
How does it perform ?
Inboard of each of the rear swingarms is a diagonal strut which provides a mounting point for what looks like a motor mount, so it gives an elastomeric suspension. It works quite well, and I am able to ride over fairly rough terrain, and even ice without slipping much. Here's a bigger picture:https://i.postimg.cc/TwYy4LJD/2wheel-drive-2.jpg
Thanks for that very informative.
