Does anyone remember a CAD drawing done of a single sprocket driving 2 free wheels ? old forum ?
Off old forum :-
The sprocket was sandwiched between 2 free wheels and bolted together with 6mm ? bolts through the free wheel teeth ?
Was it for a pseudo 2 wheel drive for a delta ? or something else ?
Seem to remember a Australian being involved ?
Savarin ? maybe ???
Lothrko.
That is not what I remember ...
However beautiful workmanship as always , very innovative driving a drum brake like that
Wasn't it the Aussie guy that was based in China; who then went back to Oz.
Steve?
I think it was TickTock based in China & Oz.
I think I know what you are talking about. I recall seeing something along the lines of:
Take two freewheels and place them cheek to cheek.
Lay a bolt across the two freewheels between the teeth - where the chain rollers sit.
Remove the bolt.
Sandwich a drive sprocket between the freewheels.
Drill holes through the sprocket so that the bolt can pass through it.
There is your single sprocket/double freewheel drive.
grabcad.com is a good source of CAD files for many different things. Saw it in a video the other day.
vk3ckc
Yes that sounds like it , I was curious how the drive got from the inner freewheel part to the drive shafts ?
Fattybb
Sort of ?
Where you have the blue piece there was a single sprocket held by bolts to the freewheels.
Great Mills, MD
Apologies for being (very) late to the party, but is this what you're referring to? These were from a thread by Savarin for a freewheel differential design to drive both rear wheels on a delta trike.
That is how I would make it.
Nice images.
Oh my... I think this has finally clicked for me... Seeing the bottom portion of the picture, the angle really helps. I think what I fail to understand now is do the same bolts go through the entire diff?
I believe they do then the free wheels screw to the collars and the shafts fasten to the collars with the grub screws ?
However I have not built one.
Just always though they were neat and wish I had a use for one .......
