I'm just getting the bits sorted for my delta build and one of the MTBs has a suspension front fork. The bike is actually aluminium and I'd imagined the forks were also but the unit seemed really heavy when I took it off. Tested with a magnet and it is in fact all steel.....BUT. The saddle thingy which has the steer tube and fork tops fixed to it is ally? Don't know if this is usual and such a fork is thought of as an ally fork or this is a steel fork with an ally top??.
The thing is a pretty substantial looking casting but obviously both steer tube and fork legs must be press fitted into it I assume. This part must take the largest bending force of the whole front unit I would imagine and since I am likely to be putting my front hub motor (500w) wheel on it at some stage will have even more stress applied.
Will this unit be safe to use or should I forget it and stick with one of the all steel unsprung units? If I change my plans a bit and use a motor drive to a rear wheel instead would it then be considered strong enough?
Thanks
Thanks
