Jon's Warrior Build
Next week I go yo a bike store to talk about the drive train for my trike. He will also put it togheter for me.
I don't have the tools and don't want to invest in that.
They did it also for my other trike.
Ontario, Canada
Around here, right now, its almost impossible to get work done on a bike at a local bike store - they are all completely swamped. I could probably get it done at the co-op, but I prefer to be able to do it myself, so I'll see how these 3D printed tools work out.
Here it is terrible. Most shops only help as you by trough them. Just a few want yo help and one is a BMX shop. He is great and made my last wheels. I go again to him. Very nice guy that delivers great quality for a very low price.
One shop was terrible. They couldn't even help me with my drive train. Even as I ordered it trough him. I found an other shop for that and if needed I can go to the recumbent bike shop.
The shop in my street also only helps as I order trough them, but he helps me with small stuff, like brake cables and stuff. Don't have too look online for all those parts.
Worth pointing out Amazon sell the relevant tools too with the usual next day delivery if the plastic tools fail.
Ontario, Canada
It looks good. Do you have the tools to do it yourself? To check the tention?
I looked also ad videos on YouTube for that. I only did that so I could finish my 3D model. Wanted it to look good.
Ontario, Canada
Some more random welding bits tonight...
First, setup to start welding the 14.5 degree angle for the steering system:
I've welded it, but going to wait until it cools down to grind it and make it look pretty.
Second, I welded the little square closed at the back of the seat bottom post (no picture). I also welded the handlebar steering gooseneck piece (the one inside that you cut the middle out of and weld back together).
In related news, I finished tuning my two front wheels:
I'm very happy with how they turned out. Unfortunately for trike building purposes, I will be out of town Friday through Sunday, so no weekend work on the trike.
Ontario, Canada
No, I removed it from the other side. I need the clearance that the spacer provides on the rotor side - otherwise, the rotor would hit the axle mounting tab.
I removed both sides and placed a nut in between with some spacers.
Does the wheel still spin good with that spacer?
As it works, than it's a good solution.
Ontario, Canada
Yeah, the spacer pushes on the side of the rotating inner race on the bearing, which is what is supposed to happen. On the outer wheel side, the edge of the nut pushes against the side of that bearing inner race.
Here's a really crude and simple cross section of what I think it looks like:
The spacer also has a dust protector which holds it in place, but that doesn't contribute to the rotating part of this at all, so I didn't bother including it.
I'm planning on using a nylock nut when I mount the wheels for real, so with the outer spacer in place the nylon part is basically just barely on the threads, thus I decided it would work better without the outer spacer.
Ontario, Canada
Here are some closeups...
First, showing the clearance (or lack thereof) between the disc rotor and the axle mounting tab:
Second, showing a closeup of the nut side. You can see how the nut is beveled around the outside edge, so only the inner band tightens against the inner bearing race:
And here are the two M20 nuts I have, normal for use while I'm building the trike, and nylock for final application:
I would put the nuts on the other side.
Looks better and it sticks out less. On the underside of the trike you have enough space.
I like the Imbus bold. Looks good.
