Warrior front wheels question?
Ohio
On the warriors I built it seems like the front wheels were always a trick to tighten enough, but not to tight, fight with spacers to make the 5/8 bolt fit the 20mm hub etc
I just saw these at lowes and they fit perfectly into the hub, reduce the hole size to match the 5/8 bold and the flange would put pressure exactly where it needs to on the bearings.
Anyone see an issue using them, would bronze hold up?
Bronze should be fine. I've had the ally 15 to 12mm spacers in a hub and they were fine. I'd beware of using 3/4 as a substitute for a 20mm bolt though. 3/4 is only just over 19mm.
