Winter rebuild
Cable tie alternatives
Broken Arrow, Oklahoma
Thank You
I did have welded on cable management in the past however does not really work when building 6 test trikes in 10 months ?
So what I use now are re-usable cable ties , when I know they are in the right place I just shorten them till they are about an inch long , that part can usually be hidden from view somewhere.
Ohio
Below is a post where I talked about how I did my cable routing and a link to the cable ties I used. I did this with two warriors and a tomahawk at the same time and the process of how I worked through where to weld on the cable ties. If you zoom in on the pic you posted above of the frame I made before powder coating, you can see a few of them.
